Permanent Horn...
cartmel808
I've fitted a Vespatronic 12v ignition to my non- battery GS160 & when the engines running the horn/buzzer is permanently on - but stops when I press the horn button?
It's got a new beedspeed standard 6v loom in with additional wiring added for the 12v reg, a new 12v brake light switch & a new 12v conversion light switch... all wired as per the supplied wiring diagram from beedspeed.
The main live (green) feeds direct to the horn & then to the light switch.
Any suggestions on what I might be doing wrong??
Cheers - Graham.
wack 63
Main scooter: '71 GP TS1
Check the horn button contacts when pressed and not when in the out position
shaunmc
Main scooter: Lambretta GP200
Permanent horn eh,
That sounds familiar.
Hope u got it sorted
cartmel808
Wired up a different switch tonight & seems to have cured it - cheers for replies...
    Users browsing this forum: Semrush [Bot] and 11 guests
