float pivot pin stuck
Suede Ed
Main scooter: SIL GP200
Anyone got a tip to remove a pivot pin from a dellorto (standard SH) tried pulling with long nose pliers, no chance, do i have to destroy the float? Cheers.
Tractorman
Try warming the pillars with hot water and use vise grips instead of pliers.
I can't remember whether the pin hole / drilling goes all the way through on an SH or Jetex, however, on one or t'other I have managed to start it moving by poking the other end, then got it loose enough to remove from the correct end.
Good luck with it.
HxPaul
I've removed the pin using a vice,their was just enough of the pin to grip with the vice and pull it out.
Suede Ed
Cheers chaps, got it out using needle nose mole grips, following the carb being left in my new (off ebay) ultrasonic cleaner, ill put a post up on this later, including pictures.
