dirty trousers
oggy
I have wot i believe to be a yam /mb master clylinder that leaks on my strides from inside the lever part ,how easy to cure as never had one . Cheers. :D
lofty
bung them in the washing machine witha bit of persil.. that should do it.. :lol:
andylaw7
:lol: :lol: :lol: :lol: :lol:
DMC
lofty wrote:bung them in the washing machine witha bit of persil.. that should do it.. :lol:
PMSL :lol: :lol: :lol: :lol:
sidebottom
Playstation gamer tag: 1DDKSA4
oggy wrote:I have wot i believe to be a yam /mb master clylinder that leaks on my strides from inside the lever part ,how easy to cure as never had one . Cheers. :D
Ride naked
Come on lads hes suffered enough..Im not sure of this because I havent got a front disc set up..BUT ive had plenty on bikes and from memory isnt there a o ring seal type object inside where the lever is...from memory again it might be the front brake light switch if these have them which it shrouds and if this is correct it might have perished or split from some reason.and its prob the problem oggy.. ;) and by the way if brake fluid has spilt on your togs bud there knackered as its highly corrosive...Just watch ye nads.. :o
oldbiker
all oil can cause serious skin problems, brake fluid removes the natural oils from your skin. this may cause dermatitas, eczema, oil achne, and if the contact is frequent or prolonged may cause skin cancer.
treat oil as a potential health hazard and try to keep contact with any oil to a minimum.
Well that set a happy tone. can you tell I have H+S qualifications
I find ST90 with prolonged use makes my hands soft as silk... :frog: ...mind you me nails keep falling of though.. :shock:
oldbiker
Lam46 wrote:I find ST90 with prolonged use makes my hands soft as silk... :frog: ...mind you me nails keep falling of though.. :shock:
I think that could be a good look, and you would never catch your nails on your birds stockings
Stokie
Am I still OK using the Vaseline ?
