Fitting New Chain......Help!
rainbowrunner
Main scooter: Series 2, RT 195
changing the front to 18 will alter the gearing to what you had before !!
eadmr04
Yeah cheers rinabowrunner, just wanted to have it standard.
eadmr04
Got the scooter up and running after fitting new clutch plates, spring, front sprocket and chain. I've noticed there's a bit of a rattle when the scooters running and it sound's like it's coming from the chaincase. I've fitted a nylon top slipper and lower chain guide and adjusted the chain to have about 6 to 7mm up and down slack in it. I've taken the casing off again and can't see anything that's been rubbing or loose? Just wondered if anyone has any ideas, I've tweaked the lower chainn guide so it doesn't look like the chain touches it any point but just wanted to ask opinions before putting it all back together again?
Cheers.
