Will a 25 mm phbl breathe through a series 2 airbox well enough as the neck is narrow ?
If not , will a series 3 airbox slot straight in ?
Thanks
Air flow for a 25 mm carb
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
I have a 1960 series 2 and I was told that the top toolbox fastener would catch on a series 3 airbox,stopping it from fitting.I had a series 3 airbox so I tried it and it fit........only just,but only just is just enough.
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
I drill some 1/2inch holes in the series 2 air box and had no problems with air flow.
rainbowrunner
- registered user
- Main scooter: Series 2, RT 195
- Contact:
I have a 25 delorto on my series 2 running through the airbox, its the wide necked one with no extra holes, changed the air scoop for a bigger flow , runs flawless with my RT195 kit
Do you know what the jetting is for your 195 set up ?
rainbowrunner
- registered user
- Contact:
no sorry, H Bomb scooters fitted the kit & carb
