Suzuki 190 set up ?
stew
Main scooter: Series 1 and series 2
Give Chiselspeed a call , good customer service ( something some dealers could learn from) and you won't have to sell a kidney
Loud pipes save lives!!
li150ss2011
Main scooter: li150silver special
chisel reprofiled my head to suit yamaha piston, £25
gaz_powell
+ 1 chiselspeed for heads
Hammerite
Main scooter: Sx150
What sort of final drive ratio would suit a 190 conversion for a solo touring rider ?
holty
Main scooter: lambretta gp
final drive ratio is influenced by the exhaust, type of gearbox comes into play as well, as does the tune of the barrel, your weight and size, do you ride solo, is it hilly near you, i opted for 5.1/1 on mine as a guess i cant say it will do you for sure but might be a starting point, that was a pm pipe gp150 gearbox, porting work quite coservative, not run yet as the frame needs paint.
mawso
Mine runs LI 150 16/46 with a final drive ratio 4.9. Full length TV barrel, 115mm conrod. Have run it with an MB Rev-Tour, RS44 Clubman and now a MSC Micron,porting is quite restrained but not had any trouble with flat spots or not pulling in gears. Great engine that sits comfortably with TS's in riding group.
kejj
mawso wrote:Mine runs LI 150 16/46 with a final drive ratio 4.9. Full length TV barrel, 115mm conrod. Have run it with an MB Rev-Tour, RS44 Clubman and now a MSC Micron,porting is quite restrained but not had any trouble with flat spots or not pulling in gears. Great engine that sits comfortably with TS's in riding group.
What size packer at the cylinder foot do you use with the 115 conrod?
________________________
http://tv175.wordpress.com/
mawso
2mm base packer I believe, no head gasket.
Hammerite
Main scooter: Sx150
What squish should I be aiming for fellas ?
holty
Hammerite wrote:What squish should I be aiming for fellas ?
Off the top of my head I set mine at 1.2 mm
    Users browsing this forum: Semrush [Bot] and 67 guests
