Gear selector/ sliding dog wear
fluff34567
Are there any set measurements /wear limits for the fingers of the gear selector? Mine is rounded...
Replace or is it OK? Will be in a non tuned engine
Scooterdude
It doesent seem to have to much wear unlike mine that started jumping out of gear so I'd use it if you have no gear jumping issues.
fluff34567
Found a SIL one for £25 so for the time and hassle of changing it if it does jump in a year or 2 I don't mind the small cost
holty
Main scooter: lambretta gp
fluff34567 wrote:Found a SIL one for £25 so for the time and hassle of changing it if it does jump in a year or 2 I don't mind the small cost
a good plan, i would have changed it as well, you know it will last longer with a new one.
storkfoot
Compare the smoothness of the track that the bearings run on with the original. I had a SIL one that had a rough track which made gear changes a nightmare.
fluff34567
Will do
SIL ones can be very crotchety. I'm using one. And while it has improved with wear I still can't get it into first gear without the engine rolling.
    Users browsing this forum: Semrush [Bot] and 66 guests
