Creeping backwards when revved
Blenks
- Main scooter: Lambretta S3 Li150
I have noticed recently that when I start the Lammy and it is on the stand, if I tweak the throttle the scooter creeps back slightly. It is fine whilst idling but as soon as I give the throttle some revs is creeps backwards. Any ideas
- Toddy
- Main scooter: Lambretta Series 1
In Gear ? or just Vibrating on the stand ?Blenks wrote:I have noticed recently that when I start the Lammy and it is on the stand, if I tweak the throttle the scooter creeps back slightly. It is fine whilst idling but as soon as I give the throttle some revs is creeps backwards. Any ideas![]()
Blenks
No not in gear, just in neutral ticking over. If I twist the throttle to rev the engine it moves backwards. It is not vibration as it does not move when ticking over and is a definite backward movement.
gaz_powell
its just creep from vibration - often happens when your stand/struts aren't perfect and the bike isn't planted on the ground - check your stand feet aswell.
Blenks
The stand feet on it are aluminium so I had a thought that it may be because they have no grip. Seems very reasonable. Thanks for the suggestions. Looks like a new pair of feet then. Cheers.
- garry inglis
- Main scooter: ts1 230 and rb200
rubber is best
