Sip/AFR valve
essexgp
Main scooter: Indian Gp200 Indian Gp Cutdown
Can you fit a SIP valve in an AFR tubeless alloy rim?
storkfoot
Don't know (sorry, I know that doesn't help) but just to suggest you look at Demon Tweeks website. They do valves and valve connectors.
Is the AFR rim threaded for the valve? If so, I would imagine it would fit as the SIP ones screw in. Some motorcycle/scooter/car valves have a nut securing them on the inside of the rim.
essexgp
Its screw in on the AF rim but the SIp one seems to small
I had assumed that they were the same as led to believe they're made in the same factory and the pic on AF's website looks the same. If I can remember I'll look at some AF rims I've got and see if I can see any difference. Not too keen on unscrewing them as one snapped on me once.
HxPaul
essexgp wrote:Its screw in on the AF rim but the SIp one seems to small
http://www.sip-scootershop.com/en/produ ... m_81050300
essexgp
corrado wrote:I had assumed that they were the same as led to believe they're made in the same factory and the pic on AF's website looks the same. If I can remember I'll look at some AF rims I've got and see if I can see any difference. Not too keen on unscrewing them as one snapped on me once.
Thanks Martin, didnt want to pester you as youve been so helpful, wasnt to worried as I now need the SIP valve for the front wheel :roll:
essexgp
Dont worry, ive had a look at thread with a magnifying glass and it seems the previous owner has wrecked the thread in the rim
So that one f****d rim with a hardly worn tyre thats going to have to come off :roll: :roll: :roll:
HxPaul
Just fitted two of these valves to ScootRS tubeless rims,it may fit your rim http://www.ebay.co.uk/itm/191954297718? ... EBIDX%3AIT
storkfoot
    Users browsing this forum: Ahrefs [Bot] and 4 guests
