I would say bolt a bit too long and some signs of work on the casing so not as thick as standard.
The stator bolt only needs about 4 threads beyond the thickness of the stator plate.
Now you know the hole is there put the bolt back in and look into the hole. How much space is there? I guess the end of the bolt is just on the edge of the casing?
Hole appeared in casing via stator plate bolt!!!!
fluff34567
alanscottj
- Main scooter: Lambretta GP SS250 Casa
Will have a look tomorrow - given up for tonightfluff34567 wrote:I would say bolt a bit too long and some signs of work on the casing so not as thick as standard.
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ππ
Scooterdude
- Main scooter: Lambretta LI 125 S3
Yeah to cold out in the "scooter room" tonight it'll wait for another day..alanscottj wrote:Will have a look tomorrow - given up for tonightfluff34567 wrote:I would say bolt a bit too long and some signs of work on the casing so not as thick as standard.
alanscottj
Job done. Took mag housing off and put a bit of JB down the bolt hole with the hole at the bottom. Will also make sure I use a good thread lock when I reassemble. With the mag housing off it was clear to see that the stator bolt hole had been drilled far too deep so there mustn't of been much meat left at the bottom
storkfoot
alanscottj wrote:Not to my knowledge it hasn't mate, bought it brand newfluff34567 wrote:It's been welded before and obviously not very well. Get it welded and ground back again.
Is this a SIL casing bought from a dealer?
alanscottj
Is this a SIL casing bought from a dealer?[/quote]
Yeah, bought it Aug 2015 'ish
alanscottj
Decided to get the hole welded in the end - Β£20 for peace of mind
Tractorman
- Main scooter: Lambretta li150 special
This may have been caused by either air or oil pressure (hydraulic pressure) when the stud was screwed in especially if you put Loctite on the threads. I have known this to crack cast iron castings.
alanscottj
It could well have been, although I don't recall putting any loctite on the stud, because the stud head was an Allen key head, didn't want to risk rounding it off. It has a cut down stud in there nowTractorman wrote:This may have been caused by either air or oil pressure (hydraulic pressure) when the stud was screwed in especially if you put Loctite on the threads. I have known this to crack cast iron castings.
- Information
Who is online
