Delortto PHBH + Airbox Rubber
Scooterdude
Ok I've got a PHBH with the threaded inlet to enable you to screw a plastic bell mouth on, can anyone tell me if there is a suitable adapter to fit the Airbox rubber on instead? or a dodge that you use to make it work?
At the moment I've just put the standard clamp back on but it ain't great and tends to slip off also tried a jubilee clip but that slides off as well.Image
gio695
Main scooter: Lambretta Li125 Series3
I used the plastic bellmouth that came with the carb on one of my engines.
You need to sand it down and make it a bit smaller and with a straight edge. Nice and tight fit!
But it also depends on the carb size and size of airbox rubber off course. It doesn't work with all phbh's
HxPaul
Failing all else,just put a tiewrap(spelling)that fastens around the carb and the rubber hose.
gio695 wrote:I used the plastic bellmouth that came with the carb on one of my engines.
^... exactly what I've done previously and the results were very good. I used the grey plastic trumpet, cutting it back and taking off the external ridges. This then fitted very well with a standard SH2/22 air hose.
Scooterdude
Cheers Adam this is exactly what I've done gone for one of the longer ones off Beedspeed.
I got a little alloy bell mouth that lets you fit the standard airbox rubber to the phbh, thinking being that the hose was still wider than the carb venturi.
Don't know if they're still available.
Scooterdude
rosscla wrote:Near the bottom here
viewtopic.php?f=10&t=30622&start=20
Looks great can you remember were you got it?
That's the problem, I can't, was something like 'alloy parts' or similar I think it was somewhere in the southwest and they did a lot of British bike stuff
Scooterdude
I've got it sorted now anyway with the plastic trumpet cut down to size, makes for a nice tidy fit now.
