lambretta clutch cush
holty
Main scooter: lambretta gp
ive been looking at a few various clutches from motorcycles to see if i could attactch one to a lambretta crownwheel , this is intended to go into my rotax 290 so must be able to handle high bhp and torque, my thinking is it might help give the gearbox a longer life,i was thinking i would have to extend the cover outwards with a packer to give enough room,has anyone had any success doing this in the past,
thanks in advance,
holty
Is that not the same as the SI crownwheel?
holty
youve lost me there adam, ?
Rear crownwheel with inbuilt cush drive, as per Series I...
https://lh3.googleusercontent.com/-oNsV ... 6%2Bth.JPG
another example...
https://www.picclickimg.com/d/l400/pict ... talian.jpg
Knowledge
To be honest Holly, your original post is a bit short of info. It is only in the title that you mention a cush, but not in the thread itself. However, this is what Adam has picked up on.
What do you want? A motor cycle clutch with integral cush, installed in a Lambretta casing?
Martin
holty
hi , sorry i didnt explain myself very well, i want to make a cushdrive to fit into a lambretta crownwheel,that fits a lambretta engine casing it will need to be very strong as it is for my rotax 290 conversion,so i was thinking of adapting a motorcycle clutch that has an inbuilt cush, i will have to pack the side case out which i dont mind doing, i have a yamaha clutch with cush drive i thought about using but that clutch dissengages with a pushrod through the center so the pushrod would have to come from the inside which is no good, i will need the clutch to be pushed in from the outside as a lambretta clutch is, hope that makes it a bit clearer,
cheers,
holty
^... yep, I get it but thought it interesting that you might be thinking back to the concept behind Innocenti's initial SIII (and earlier) clutch design. Indeed, did I read somewhere (Scootering's review of the original Innocenti twin motor?) that Innocenti had resorted to fitting a sprung rear sprocket to the twin as the front sprocket does not have the typical front sprocket transmission damper?
When it comes to fitting a motorcycle cush clutch to a Lambretta, best I sit back and watch (with interest) whilst you do it!
holty
i intend to keep the front damper as well, i just want to give the gearbox an easier life, if you can do that with a high output lambretta engine,
cheers adam
holty
joespeed
hi mr holt,i do believe casa have done such a cush drive in their latest clutch for their high horse power case/kit,have a look on their website.does look nice which usually means expensive!
holty
joespeed wrote:hi mr holt,i do believe casa have done such a cush drive in their latest clutch for their high horse power case/kit,have a look on their website.does look nice which usually means expensive!
hi joe,
yes i have seen those, i didnt even find out the price as i know they will be over my budget, i want something thats affordable and works without a massive price tag, im sure i can find a motorcycle clutch that i can make work, a visit to my local bike breakers is in order, thanks for the pointer. :D
    Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
