fork link identification
thackers
Hi, could someone kindly confirm the source of the disc hub fork links I've just bought? They were sold as G.P ones but the spot where the ball bearing on the end of the fork push rod sits seems too big. They have a grease nipple on the underside if that helps? So if they are the S.X /T.V type will they work with push in buffers that G.P forks have.
Thanks
storkfoot
By the sounds of it, you're right. They are non GP but there's no reason why the won't work in GP forks.
