Panel locks.
10 inch Terror
Xbox live gamer tag: No.
Hi all,
After recently losing a panel I'll going to fit some panel locks. The locks are the small type that you get on data cabinets etc. Has anyone got the dimensions and measurements of where best to fit them please? Thanks in advance Pete.
gaz_powell
Fit them in line with the rear frame grille
gaz_powell
Timbo
I have an SX with standard Spring clip (not rollers) and I simply put a very small jubilee clip on the end once the panel is on. Does the job and should stop the chancers/scum bags. I've not done anything about my GP clip on panels but thought a very small screw at the very bottom of the rear of the panel. Anyone got any ideas?
HxPaul
10 inch Terror wrote:Hi all,
http://www.ilambretta.co.uk/forum/viewt ... rity#p4660
10 inch Terror
Thanks chaps.
gaz_powell
im sure you already know but if not you need 20mm deep - pair keyed alike
10 inch Terror
gaz_powell wrote:im sure you already know but if not you need 20mm deep - pair keyed alike
Yes mate. I've already fitted them. Thanks anyway.
10 inch Terror
Just thought I'd add that the panel wasn't stolen, if came loose and fell off.
fluff34567
Photo if possible?
    Users browsing this forum: Majestic-12 [Bot] and 5 guests
