Anyone know of a how to post on refitting a gp 150 kick start reassemble please
sent from over there next to the tree
GP KICKSTART REASSEMBLE
Any help please
- registered user
- Main scooter: Lambretta
- Contact:
What do you need to know?
Sticky's Spanners Manual is the best £20 you'll spend on your Lambretta.
Yeah bought that, when you put the casing back on do you have to have the lever depressed down then release once the casing is engaged
gp side case yes or plunger pushes side case awaydazblakey wrote:Yeah bought that, when you put the casing back on do you have to have the lever depressed down then release once the casing is engaged
C’est la vie
fairspares
- registered user
- Main scooter: Lambretta GP RB252
- Contact:
Only if you have GP type endplate but then you only need to press kickstart shaft slightly to clear the ramp lower part.
Ok guys thanks I think I understand
fairspares
- registered user
- Contact:
With li type ramps built into the side case the kickstart plunger is already pushed in after assembly , with GP casing using GP endplate as the casing goes on the plunger will hit the lower part of the ramp so you need to move the kickstart shaft round slightly to clear the ramp once on when you let go the plunger pin engages in the ramp moving the plunger same goes for removing the casing .
