damaged crankshaft oil seal face?
scooterslag
I was removing the bearing collar by dremeling a notch in the collar and using a chisel to tap it off when I slipped and scuffed the taper,
as you can see where I've circled the scuff - its quite near the flywheel side seal, its not a deep mark but you can pick it up if you run your fingers over it, is it knackered and would damage the seal or could I smooth it down and use it? thanks Paul
The mack daddy on the left!
warts
Main scooter: honda
We used to use repair sleeves with success.
https://simplybearings.co.uk/shop/Engin ... index.html
Daggs
The dark line running round the area shows where the seal runs. Smooth any roughness (to prevent inner seal damage on assembly) and carry on.
Tractorman
Main scooter: Lambretta li150 special
Daggs wrote:The dark line running round the area shows where the seal runs. Smooth any roughness (to prevent inner seal damage on assembly) and carry on.
agree.
scooterslag
great, thanks for the replies, Paul
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
