Compression on TS1?
alanscottj
Okey dokey, decided to take top end off and have a look. Barrel is spotless but checking rings, put top piston ring into the barrel and the gap is 0.8 - does this mean it is time for new rings?
garry inglis
Image this is watt mb recommends
garry inglis
So 0.8 seems big and might be why the compression is down
alanscottj
garry inglis wrote:So 0.8 seems big and might be why the compression is down
Yup, measured them both and both are larger than recommended - top ring 0.8 and bottom ring 0.7 :(
garry inglis
Easy to sort out Alan and you only have to take it easy for 50 miles and should be a lot more responsive
alanscottj
The piston that I have is a 'B', does this have any bering on the rings I need to get? Or, can I just order normal TS1 225 piston rings :?:
Padge
Main scooter: 1969 Lambretta gp
just order normal TS1 piston rings and gap accordingly
alanscottj
Padge wrote:just order normal TS1 piston rings and gap accordingly
Cheers Padge :D
garry inglis
How many miles on those rings and what 2 stroke are you using just to understand why?
Scooterdude
Also what's your piston to bore clearance am guessing it should be around .003"
