TV175 1963 strip and rebuild
fluff34567
Today i patched up a few holes where edge trim and other bolt on things used to be.
fluff34567
Today i walnut blasted the frame to strip the paint. Frame has cleary been blasted before as it has a rough texture. As it had fine surface rust everywhere I had to spend ages in the oxide machine to strip that... here it is near the end. Image
https://youtu.be/djlEPbswqNQ
fluff34567
Frame primed with zinc chromate so a rather fetching puss green.
After a while I'm wishing the blasting cabinet was a bit taller.. oh my back!
fluff34567
Piston measured today... should be fine but need to check about the ring area dimensions and do the "traditional" way of measuring the cylinder/piston gap. Image
