Running Issues
You have checked the petrol cap breather is clear?
Stator tested fine and I put on a cap that worked fine in another scoot. Thinking about changed the mag bearing and seals
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
I know it's a big place where you are, but aren't there any other scooterists that could help you out?
I took off the petrol cap and gave it a run. I couldn't get it to play up but the noise from the mag side still sounds a bit rough but they all rattle about a bit
If the pressure plate area was leaking air wouldn't it also burn engine oil?
The spark plug colour is good.
holty
- Main scooter: lambretta gp
if you have an air leak it will cause problems, the main one being you will melt your piston if you ride it long, or hard enough, air leaks also give other symptoms, erratic tickover, sometimes stalling, but sometimes the revs will not drop correctly when you shut the throttle, i would suggest you do a leakdown test, if you have an air leak it will be very obvious, could easy be the best money you ever spend, its already been sugested by others, it will narrow down your search to whats causing your problem, a plugchop might give you an idea of your mixture but wont tell you about a leak, thats what i would do if i was you, i suspect others would agree.
holty
holty
- HxPaul
- Main scooter: lambretta Li 150
If you mean the plate that holds the main engine oil seal,it would burn gearbox oil.Lamaddict wrote:I took off the petrol cap and gave it a run. I couldn't get it to play up but the noise from the mag side still sounds a bit rough but they all rattle about a bit
Update.
Air leak test good.
I had some grease coming into the stator area and I always wondered if I got the mag bearing in properly. Anyway, I put a new mag bearing in, seals, gasket and even a new BGM Stator. Took it for a run, exactly the same. The only things left now are the crank, flywheel and fuel tap. I changed the fuel tap and that bloody sorted it!!!
Air leak test good.
