ADS3 & ADS Touring/Rally - What's the Difference?
servetakid
As the title says, is there a difference?
Jordan
st0kky
Main scooter: lambretta S1 RB261
if you ask Martin at Chiselspeed you'll get the best answer
he designed the pipes !!
camel
The nk rally is sold through AF...the ads 3 is sold through chiselspeed...same manufacturer and similar design...although the nk rally revs further and a good alrounder the ads3 is all out torque with less revs
I think Chiselspeed have changed the names from ADS3 to Touring / Rally and ADS5 to Race, but as already mentioned best speaking to Chissie direct in case they've changed the pipe's characteristics in any way.
Adspeed
st0kky wrote:if you ask Martin at Chiselspeed you'll get the best answer
:shock: ......... :D
Yes .... but what's the answer to the question? And can you redesign the ADS3 about 5mm thinner at the kickstart side bend, mine touches the cowling bolt with a 3mm base packer?
servetakid
Martin has confirmed that the exhausts are the same. Now im just trying to decide if it is the best for what I want to do.
    Users browsing this forum: Semrush [Bot] and 49 guests
