oiltech casing alterations
garry inglis
Hi the case was£350 including endplate from lambretta restore its a ts230 with a gt60/110 crank li150 gearbox 46/16 /4.9 porting to barrel head and barrel pinned as I used a 2.5 head packer and 2mm base packer and an ads5 road/ race exhaust with a 30 mm vhsh carb iam going to put it in my Spanish li150 which has a rt 195 in which goes really well
garry inglis
Well I finished it off today had the reed speed 5 plate soaking in oil overnight ready to go in I'll have to strip the other engine outImageImage
225worb
Main scooter: Vespa 225, Falc , 230 S2
Yes please Gary....
garry inglis
Well it's up and running a few tweaks and alls good https://vimeo.com/202021354
garry inglis
https://vimeo.com/202021532
dazblakey
Sounds crisp
Sent from my D6603 using Tapatalk
HxPaul
It may be an optical illusion,but the nut on your engine bar doesn't seem to reach the nyloc part.
garry inglis
Eagle eye hxpaul iam fitting offset cones so they are just on
Strummer10
Well done all done then.......
I couldn't quite download the video (might be my pc)
Standard cylinder head or mammoth head ?
Like the exhaust ......where from / how much ? How does the Reedspeed 5 plate clutch compare to the AF cassette one.......I've heard good things on the Reedspeed.
ForemanBob
Main scooter: GP RT230
Just been told that Oiltek not doing any more casing alterations...
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 3 guests
