Hi all can any one recommend a good tensioner,I've read about the pull down tensioner and rather fancy one, if any has some experience with all types please speak and if you got pictures to would be great
Sent from my D6603 using Tapatalk
Recommended gp chain tensioner
Tractorman
- Main scooter: Lambretta li150 special
The GT tensioners are excellent.
- ForemanBob
- Main scooter: GP RT230
recently tried the GT tensioner, but the sliding bolts at the back caught on the casing, and couldnt loctite the main bolts in position at the beginning. But a good value piece of kit... Jockeys Boxenstop pull down tensioner has to be my favourite though; although if you are using a slightly longer chain than expected you may have a bother trying to tighten the top bolt....
Anyone tried the casa one yet?
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
I used these from AF in a lot of engines, always thought they were good value.
Do like the look of the casa for the extra buck
fairspares
- Main scooter: Lambretta GP RB252
I agree with Dan on this, these are simple , uncomplicated , i remove the 2 screws and loctite in for safe measure , ive now been using for a few years in my own sprint and tuned motors.drunkmunkey6969 wrote:
Just looked on AF there's two one of price of the other the cheaper of the two says needs drive plate screw, excuse me for being thick???fairspares wrote:I agree with Dan on this, these are simple , uncomplicated , i remove the 2 screws and loctite in for safe measure , ive now been using for a few years in my own sprint and tuned motors.drunkmunkey6969 wrote:
- drunkmunkey6969
- Moderator
The expensive one is the LTH version, the cheaper one is the AF copy. I use the AF copy.dazblakey wrote:Just looked on AF there's two one of price of the other the cheaper of the two says needs drive plate screw, excuse me for being thick???fairspares wrote:I agree with Dan on this, these are simple , uncomplicated , i remove the 2 screws and loctite in for safe measure , ive now been using for a few years in my own sprint and tuned motors.drunkmunkey6969 wrote:
Order a drive side plate screw with it for fitting.
fairspares
A copydrunkmunkey6969 wrote:The expensive one is the LTH version, the cheaper one is the AF copy. I use the AF copy.dazblakey wrote:Just looked on AF there's two one of price of the other the cheaper of the two says needs drive plate screw, excuse me for being thick???fairspares wrote:
