TS1-225 - standard
Varitronic ignition
Franspeed SuperTourer
TMX 35 open carb
Set up by Chiselspeed on dyno last year.
Many thanks!
Dead right but I'd expect it to show double. You'd probably need to configure the tachometer as if it were fitted to a twin.mick1 wrote:The Varitronic, having a double spark, can sometimes cause problems with the readings......
hendy wrote:Dead right but I'd expect it to show double. You'd probably need to configure the tachometer as if it were fitted to a twin.mick1 wrote:The Varitronic, having a double spark, can sometimes cause problems with the readings......
