Rb manifold rubber
maxi
Main scooter: LIS 190
Hi all,
Is anybody else's carb running this close to your engine mounts?
RB20 with step down rubber on Spanish case's. All gaskets fitted correctly.
Ride it hard
Boreham
Main scooter: GP225
Hi, yes exactly as mine as well, when running and the rear shock compresses it does miss (just)
Never had any running issues.
Knowledge
You could fit a longer con-rod and a packing plate in order to space it off the engine mount, or is that a bit drastic?
Martin
garry inglis
Mine has about 2mm clearance so I ground the bolt down to halfway and got 5mm
fairspares
My Rb with standard manifold was very close to the large engine mounts, ive now got the LTH manifold fitted and it has a lot more around 8mm clearance.
    Users browsing this forum: Ahrefs [Bot] and 2 guests
