Trail tech supplier
chippy
Any one got a trail tech vapor off moorespeedracing. The Lambretta kit seems to have everything included
garry inglis
my mate got one were just about to fit it during the build a great package
chippy
You fitting it into headset or toolbox
garry inglis
Toolbox it's ac so connect to brown from loom
garry inglis
the stood for the speedo magnet is good and we have used an old bolt on shock mount to attach the pick up
chippy
Good idea, I've been toying with the idea of getting the ally housing and fitting it into headset, toolbox is one of the nanucci type and there isn't a lot of room. I will be just running the live to the headset as yourself
alanscottj
Got mine from Moorespeed - fitted in no time at all - has worked perfect since I set it up and speed is spot on. Ended up putting a battery in my oil carrier just to feed the EGT and the Trailtech - much, much brighter and battery lasts months before I have to re-charge. Great bit of kit imho :D
chippy
alanscottj wrote:Got mine from Moorespeed - fitted in no time at all - has worked perfect since I set it up and speed is spot on. Ended up putting a battery in my oil carrier just to feed the EGT and the Trailtech - much, much brighter and battery lasts months before I have to re-charge. Great bit of kit imho :D
Thanks for that, I have ordered one off them this week so that is reassuring
chippy
So, alanscottj. You just connected it direct to a spare battery and not to live feed in headset. Just a normal bog standard battery. Thanks
alanscottj
chippy wrote:So, alanscottj. You just connected it direct to a spare battery and not to live feed in headset. Just a normal bog standard battery. Thanks
Yup - battery from Maplin then put a switch and a fuse in between the battery and the Trailtech and it's been spot on ever since (so long as I remember to switch it off when I put her away!) :D
