TS1 & VHSH 30
Boreham
Main scooter: GP225
Tried several searches, anyone have a start point for this carb, the needle selection is endless!
TS1 with Franspeed race pipe.
garry inglis
I've just picked one up on Friday of Ben at rayspeed and as mine is a new build ts230 it's set rich 155 main 48 pilot aq267 and u16 needle 60 choke standard slide
Boreham
Main scooter: GP225
Thanks Gary, can i just confirm the atomiser is a DQ267, the AQ is listed for the smaller PHBL carbs?
garry inglis
Yes dq
garry inglis
Hi just to add the needle on 3rd clip to start then drop to 2nd possibly
Boreham
Main scooter: GP225
Cheers Gary, just need to track down a U16 needle.
Boreham
Main scooter: GP225
Boreham wrote:Cheers Gary, just need to track down a U16 needle.
Dellorto UK, £10.34, cheers for the info!
garry inglis
no probs i have one on my rb200 with franspeed race vertually the same jetting to start but changed to k21 needle 40 pilot 150 main now the k21 is for the 34mm but still fits or you can get away with a k8 if no k21 and a dp267 atomiser
Boreham
Main scooter: GP225
Hi Gary,
Did the carb come with the blueprint modification or will you carry this out?
Cheers
garry inglis
I don't think that's a problem anymore I have just fit mine no problems fastflow tap 300valve I think you had to drill the half round out 2.5mm if I remember iam getting a slight spit back on panels and it goes like you stole it so iam happy with my setup
