My new ride
LI150
Main scooter: Series 2 LI150
Past Mot yesterday now to register.
Gt186, copy taffy pipe, 30mm dellorto, Jet200 tank, sip speedo, bgm rear shock,all fully run in as I took it from another scoot
Knowledge
Tasty. I assume the body will remain as it is?
Martin
hendy
Knowledge wrote:Tasty. I assume the body will remain as it is?
That sounds more like a command than a question! :D
LI150
It is as you see it no restoration going on here
storkfoot
Very nice. Is the front brake up to stopping it? I only ask as my current project is a very similar engine and I am going to try a reverse pull drum
hendy
storkfoot wrote:Very nice. Is the front brake up to stopping it? I only ask as my current project is a very similar engine and I am going to try a reverse pull drum
I've got reverse pull drum on my gt186 and it can stop on a sixpence. Well it could if it didn't have shitty Lambretta suspension anyway.
Honestly, it's a really powerful brake.
LI150
The brakes are good but i am thinking about a disc brake
storkfoot
LI150 wrote:The brakes are good but i am thinking about a disc brake
It's a pity that outboard disc brakes just don't look right on a Lambretta, especially an original beauty like yours.
alcoholic maniacs sc
outboard disc brakes look wank on bikes like this. reverse pull drum will do the job and look the part. without ABS over braked lambrettas are more dangerous than under braked (under baked) ones.
beautiful wheels mate.
LI150 wrote:It is as you see it no restoration going on here
What! I was on my way with the pitch fork and blazing torches. :o
