Spanish ser 2 mudguard
Daggs
The rear muddy on my Spanish Li S2 has two large holes (approx 10mm) punched into the rear lower edge. Because they are punched not drilled, I'm assuming they are factory created. Does anyone know why they are there?
whonatic
Daggs wrote:The rear muddy on my Spanish Li S2 has two large holes (approx 10mm) punched into the rear lower edge. Because they are punched not drilled, I'm assuming they are factory created. Does anyone know why they are there?
They're to fit the rubber buffer (square black rubber block) that fits between the mudguard and the frame between the two panel brackets
Daggs
Cheers whonatic. Fairly obvious when I think about it, doh!
whonatic
Daggs wrote:Cheers whonatic. Fairly obvious when I think about it, doh!
It's only obvious when you know it :lol:
charlton_supporter
Main scooter: LI150 Special
Any pictures available?
Sent from my SM-N910F using Tapatalk
kevspeed
Available from Scootopia 8-)
charlton_supporter
kevspeed wrote:Image
Thanks for that.
    Users browsing this forum: No registered users and 33 guests
