DIy cheap thumb choke conversion
Eibar
Main scooter: Eibar TS1 1966
potato
garry inglis
what a great idea what cable did use or have made one up
Eibar
BSA thumb choke £12.00 ebay . Shimano SIS gear cable inner outer £3 nylon lined with a stainless cable. Cable nipple filed down to fit in choke jet. Small solderless nipple at thumb choke end with a groove cut into chock lever to allow cable adjustment.Its a handlebar type bracket so I binned the lower section and replaced it with a flat bar of alloy.
Total outlay £15.00 and it works a treat with the ability to feed small amounts of choke if needed and it locks out in all postions as tension is set with centre screw. I didnt do this to save money, just to prove it could be done as many have made other great versions before me.
potato
Knowledge
Neat.
BTW, if you have to solder your own nipple on, then a mild-steel cable is better than stainless. If in doubt, test the cable with a magnet.
Martin
Eibar
and fzr600 is a crackin version martin
potato
jason frost
I use the gear change off a push bike , they have a few clicks on them so you can just open it a bit at a time and leave it
garry inglis
whats the mount on top off the hydraulic bowl is it a rev counter
Knowledge
Eibar wrote:and fzr600 is a crackin version martin
For those that haven't seen this, here is a photo.
Martin
Eibar
garry inglis wrote:whats the mount on top off the hydraulic bowl is it a rev counter
yeah sendec rev counter and a little mounting block that fits to master cylinder with grub screws
potato
garry inglis
Eibar can you by them or have you made it because I'd be very interested
