Hi
Had to strip my gearbox and reassemble - once assembled its not that easy to turn by using the spider. I can turn it by hand but its not that easy. Using a socket drive it is fine.
Should I be worried, is there anything I can do?
Its not the big shim clearance causing the issue. The engine is in the scoot so its not on a bench or anything, not that I really think that makes any difference as its not in gear.
Gear bix question
holty
- Main scooter: lambretta gp
you might try fully torquing it up, if it doesnt pull through fully it can squeeze the shim on the rear of the cluster and make it tight, when you nip it up it pulls the cluster through the bearing in the gearbox endplate and it should then run smooth and free, if that doesnt fix it you might have to strip and inspect
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Google [Bot] and 7 guests
