TS1 225 Kits - advice please
Strummer10
Main scooter: Lambretta LI Special 225
Guys........with the TS1 225 kits
1/ what is the significance of using the new AF cylinder head 9.5.1 ? Does this increase compression or the opposite ?
2/ Would a BGM clubman version 3 work ok with the above kit of hinder performance.
I'm thinking of running it on a standard Italian GP 200 gearbox and sprocket set up, but should this also be changed. Was thinking a hybrid between a touring set up and around town
Strummer10 wrote:Guys........with the TS1 225 kits
1) The 9.5:1 head will increase compression if you currently have an 8.5:1 head, or decrease compression if you have a 10.5:1 head.
2) Yes it would work OK, it would increase performance compared to an AF Clubman, or decrease performance compared to a decent touring expansion chamber.
All things are relative.
Strummer10
Cheers.......no head yet as kick being considered for purchase. Would like an expansion pipe tbh but want to retain standard looks, considering a clubman type exhaust what's the best out there would you say for the set up i'm after ?
soosh
A few recommend the bgm clubman and have had good results. I don't know anyone who has used a Gori with a TS but I've got one on my iron barrel and it's fantastic.im using a JL3 curly on my TS which tucks away quite tidy and that's a great pipe.
Padge
Main scooter: 1969 Lambretta gp
drunkmunkey6969 wrote: 1) The 9.5:1 head will increase compression if you currently have an 8.5:1 head, or decrease compression if you have a 10.5:1 head.
As Dan and others have has said on here in other threads, a good clubman will be better than a cheap s**t expansion, a good expansion p****s all over a good clubman....and they sound better !! :lol:
Strummer10
Yes agreed a clubman won't meet the same as an expansion, but I was thinking of keeping it standard looks :roll:
Backing up what Dan says. AF used to offer 2 heads one was 8.5 to 1 compression and they also did a skimmed version of this that was 9.5 to 1. They recommend the 9.5 version for the TS1 & RB.
Strummer10
Cheers for the reply. Next question is there any difference in fitting a crank with a longer stroke.....'real benefits' over the standard stroke crank ?
Minority
Main scooter: Li230 S3
Longer stroke or longer conrod?
Longer stroke = more cc (e.g. your 225cc would become a 230cc using a 60mm stroke)
Longer conrod = smoother engine (and easier to play with packers/gaskets to get the port timings you want)
Strummer10
Cheers Minority................I guess it would be beneficial to have both ? therefore on a TS1 what would be optimium would it be a 115 conrod ? and can you recommend who does a crank that would fit the bill ? cheers
