Sx150
rob1273
https://vimeo.com/192161870
rob1273
I put this on before but it got poopoo'd abit. I've been offered this from Greece, it's got Italian numbers from 68. Does the vid give it anymore credibility or does it still look like a phoney
Timbo
Personally because there's so many scams around these days unless I found someone that knows the seller I wouldn't take the risk of sending money. If it's cheap you have to ask why.
I remember that. There were a few things wrong with it as I recall. So assuming you bought it you'd have to spend money on it anyway. On the plus side I don't think Greece is notorious for its scammers. I think I'd probably go on FB. There is a Lambretta Club of Hellas and one of them might know it.
rob1273
Doom Patrol wrote:I remember that. There were a few things wrong with it as I recall. So assuming you bought it you'd have to spend money on it anyway. On the plus side I don't think Greece is notorious for its scammers. I think I'd probably go on FB. There is a Lambretta Club of Hellas and one of them might know it.
Cool, will check that out
Isn't this the one that we discussed whether 'original' meant 'unrestored'? If so, the points were only raised so that you went into any purchase scenario in the knowledge that it had been worked on, rather than being 100% unmolested. I don't think that anyone was particularly trying to put you off buying it, rather, just helping to inform you of what might have been done that wasn't original factory spec.
Good luck and I hope that you enjoy it :)
rob1273
Adam_Winstone wrote:Isn't this the one that we discussed whether 'original' meant 'unrestored'? If so, the points were only raised so that you went into any purchase scenario in the knowledge that it had been worked on, rather than being 100% unmolested. I don't think that anyone was particularly trying to put you off buying it, rather, just helping to inform you of what might have been done that wasn't original factory spec.
Yep not gone unappreciated
