Fast Idle Speed
EddieStone
First thing I would do is make sure your throttle cable is seated properly at both ends.
Maladjusted
Main scooter: Vespa T5 Classic
Carb jets removed and all cleaned with compressed air. Seems to be working fine now. Must be the Sainsbury's petrol :shock:
ducksta
You could of blocked the tap with shite if you jacked it up take tank cap of and put air through the petrol pipe to eliminate this
ducksta
How did you jack it up?
Maladjusted
With a car jack from the very back of the scooter :?
GFlint
Main scooter: Vespa PX200
Might seem daft but is the throttle cable outer seated correctly? Sometimes they rest on carb housing and not pushed in right which makes it race.
Gaza
If you don't tinker, you won't learn anything, but you won't break anything either :)
    Users browsing this forum: No registered users and 26 guests
