Wheel nut query?
Scooterdude
Ok I guess I should know the answer to this but I don't so here goes. I'm replacing the stainless nylock nuts on my wheels with the correct 14mm zinc plated ones, 4 domed and 4 open nylocks per wheel but which go were? I'm guessing the domed ones are used to fix the two rim halves together and the open ones to fix the rim to the hub, am I right?
Tractorman
It is the other way around, dome nut hold the wheel to the brake drum and the nylocs hold the rim halves together.
Unless you're a stickler I'd use all nylocs. You can never tell with domed nuts.
Timbo
What's best for attaching the side casing?
DigDug
Timbo wrote:What's best for attaching the side casing?
Standard nuts and a wavy washer.....
Did you have to do that?
bristolmod
Doom Patrol wrote:Unless you're a stickler I'd use all nylocs. You can never tell with domed nuts.
fully agree!
Scootering since 1968.
HxPaul
The original wheel nuts were domed with nyloc inserts.
Scooterdude
Just to many stainless fasteners available these days, it's the wrong tensile strength for wheel fixings.
HxPaul
Although stainless steel has a lower tensile strength,stainlees wheel rim nuts should be well up to the job,after all the recomended torque setting is only 14.5 to 16.6 LBS-FT ( according to Sticky's manual torque settings) In fact MB,Casa and SR do a wheel nut kit and their stainless steel.
Scooterdude
When I did my restoration last winter I had to replace a lost wheel stud, anyway I wrongly replaced it with a stainless one and when I took the back wheel off last month it snapped clean in to.
One of the problems with the stainless nylocks is they don't seem to be the correct height thus offering less of a threaded area for tightening.
When you combine stainless nuts with stainless studs that's when the real problems start, because of the high chrome content the threads tend to bind to each other which inevitably ends up with the stud snapping.
On the other hand if you use a stainless nut but with a high tensile stud or a stainless stud with a high tensile nut you should be alright.
Titanium (not that many folks would use titanium fasteners on a scooter) is worse for thread binding than stainless.
Much better to use the right high tensile studs and nuts, mine came in the post this morning and fitting them they had a much better and more secure feel than the stainless ones I took off.
