tv 175
lammy666
Main scooter: lambretta li 125/190 chop.
evening lads, my m8 has a tv175 s3 with a gp crank, 12volt conversion and a mugello kit fitted.
would a standard 175 top end fit straight on or would the length of the conrod be a huge problem.
garry inglis
The TV had a116 special crank originally and a175 only needs a58x107 crank what gp crank is in
lammy666
think its a gp 200 crank 107 mm.
i imagine that this wont be suitable with a standard tv175 barell
bristolmod
it will be fine BUT you will need a "normal" piston (i.e. one with the gudgeon pin at the same height as an LI; SX and NOT the higher pin as per the proper TV175 piston)
Scootering since 1968.
lammy666
cheers for that guys
    Users browsing this forum: Google [Bot], Semrush [Bot] and 12 guests
