T5 bearing and seal sizes/part numbers
scooterslag
Does anyone on here have a list or link to somewhere I can find these sizes/part numbers to? cheers Paul
The mack daddy on the left!
gaz_powell
hope this help
Clutch Side 25x62x12 Ball , seal 31-62-5.8/4.3
Flywheel Side NU205 C3 Cyl Roller , seal 24-35-6
Gear Cluster 6204 C3 or C5 Ball
Gear Cluster 23No Needles
Gear Layshaft 24x28x10 Needle Bush
Rear Hub 6302 C3 Ball , seal 30-47-6
Front Hub 6202 C3 Ball
Backplate 20x26x16 Needle Bush
I only use corteco seals
scooterslag
thanks ;-)
