Electrical issue
GlosRob
Sometime ago the regulator fell off my GP and due to some engine probs I have not used it for months and I am now having problems wiring the regulator.
The ht unit has stayed wired and the wires I have left appear to be a yellow and brown is this correct and which pins on the regulator do they connect to. The regulator is a 5 pin Duccati one.
firekdp
Yellow and brown are correct, yellow power in to the reg and brown power out. With the connections of the regulator at the bottom the AC connections are normally the first two from the left, and usually marked A,A or G,G.
