Scooter died
hungdog
Holed piston, take plug out shine torch in to see it
ricardo59
Main scooter: vespa px 125-180
Thanks for all your comments will keep you posted
ricardo59
Update on my dead scooter, so i've cleaned the jets changed the plug, HT lead, CDI unit and still nothing i get one little blurp and thats it, put petrol into chamber, nothing, i'm getting a spark so just can't understand why its not firing? Have i missed something? Oh and there's definitely getting fuel to the carb
ducksta
Check the length of fuel pipe shorter the better does it run with choke on
gaz_powell
if you`ve got good spark and fuel flow, you need the top end off.
ricardo59
Hi all
I've done all i can, think its time for someone who no's what they'er doing to have a look at it...think its something to do with the oil/fuel on back wheel?
Scooterdude
My guess is a stuck/semi stuck piston ring. If you have access to a compression tester this will give you a clue.
ricardo59
You couldn't be more right! it was a dropped piston ring which fooked up everything :evil: so its a new Polini kit....don't know why it would do that? anybody any ideas?
    Users browsing this forum: Baidu [Spider] and 8 guests
