What is the best Auto advance for my set up
olliewtf
Main scooter: Lambretta Li S3
Everything is reading crystal clear everyone!
I see what you guys are saying. A quick test would be for me to strobe the damn thing, but i lent out my strobe and,well, bye bye.
Re-reading the limited info on readspeed site it doesn't make this point clear at all, yet SULK does suggest that it does indeed advance the timing. And trust me Coaster, you already know more than I about this! haha.
That said, I would still love to try a kheper in the future simply for the fact that its programmable, which for me makes it probably the best unit out there, if you feel confident enough to set it up properly.
dave411
Main scooter: Li 125
I have just read this from start to finish,my head hurts.
Chris in Margate
Whatever your opinion I have to say it is so important to establish your precise TDC and strobe your timing and note the degree of advance right up to maximum rpm.
coaster wrote:........... Perhaps the Readspeed delays for more than 360 degrees to achieve the advance??? or maybe it is just black magic lol
eden wrote:It is possible to have a system that will advance from a more retarded static setting........ it's possible to hold on to the spark till the next firing point.....In a way its actually retarding the ignition long enough to use the spark on an advanced position on the next revolution
We were both right Ollie and you won't need a Sonic Screwdriver to do the adjustments 8-) )
EddieStone
eden wrote:It is possible to have a system that will advance from a more retarded static setting. I know the kheper guy is working in it and is looking at making the is an option for kheper 3 owners via a software update.
It involves the system missing one spark and using that missed spark for the next spark.
As coaster said it's not possible to make something happen before it has but it's possible to hold on to the spark till the next firing point.
In a way its actually retarding the ignition long enough to use the spark on an advanced position on the next revolution so it's not doing what a time lord could and if was a 2 stroke rider probably would ;)
I've had a hard day at work so if what I've said makes no sense I'll opologise now lol
That's definitely witchcraft.
Eibar-Jet200
Main scooter: Serveta Jet 200
Thank you all for the comments. My question will make me read and investigate before I make my decision.
I will read this thread a few times to get the jist of it all again.
Much appreciated
John
Eibar-Jet200
Thank you all.
I will reread the thread again.
Appreciated
John
    Users browsing this forum: No registered users and 71 guests
