200 Italian fork links
mr mugello
Hi. Will an Italian drum hub fit onto Italian disc brake
200 fork links ? Cheers.
bristolmod
no
Scootering since 1968.
Yes, if it is a TV175 Series 1 or 2 drum with stud and nut fixing backplate... but these are comparatively rare to the 125/150/Spanish/Indian hubs, which have a different backplate.
So in most cases the answer will be no.
mr mugello
Ok thanks
What are you trying toachive by doing this is it because you want to keep the dampers ?
