Spare O-rings in kit
GFlint
Main scooter: Vespa PX200
Just rebuilt a Vespa PX 200 engine.
I have two spare O-rings left over and it's vexing me if they need to go somewhere. Are they just leftovers? They are slightly smaller than the ones on the rear brake cam shaft.
Anyone know?
Cheers Gary
https://www.flickr.com/photos/143575383 ... res/E6U4LE
If you don't tinker, you won't learn anything, but you won't break anything either :)
Shaunbond
Could they be for the clutch arm?
Serial scooter rider...
VMSC Committed to Scootering for 25 years
GFlint
I did think that Shaun but they may be a little small for it. Anyway I did them recently and don't want to take the stiff spring off again in a hurry :D
Gary
There should be two on the brake peg castings behind the brake backplate.
GFlint
Those are the `pair of specs o rings Ross, I have them in place. Think these are surplus.
Gary
gaz_powell
If you've done the clutch arm, kickstart, backing plate and brake cam there's nothing left on the engine.
Is the front brake cam slightly smaller than the back, could b for there. I'm not sure but there maybe diffrent size brake cams depending on year of px.
I seem to remember having left overs
GFlint
*update i should have done back in 2016
The two small O rings are for the oil metering device overhaul.
Tks
G
railfancwb
The watchmaker’s apprentice was taking apart and reassembling a fine classic pocket watch. The master watchmaker was watching closely and slipped an extra screw into the stash of parts...
