Cheap easy bridge piece fixing.
10 inch Terror
Xbox live gamer tag: No.
Hi all, I thought I'd share this little upgrade I've done to my latest project. All you need is a square file and some M5 cage nuts ( these cost £1.50 for 10 delivered ). All you need to do is slightly file the cross member opening for the bridge piece fixing point. Slot in a cage nut and you're done. The purpose made kits are £18-20 and this stands me in at £1.50. The cage nuts are stainless so should last ok. I hope this is of help to someone wanting an easy fit bridge piece kit. Cheers Pete.
Last edited by 10 inch Terror on Thu Sep 15, 2016 5:47 pm, edited 4 times in total.
Grumpy225
Clever approach. I always thought well nuts or rivnuts would be a good option also.
http://www.niagaracycle.com/categories/ ... Al3o8P8HAQ
http://www.ebay.com/itm/like/1722245603 ... noapp=true
10 inch Terror
The good thing about using cage nuts is they will slide along in the slot making them adjustable. All bridge pieces seem to fit in different positions. You also don't need to do any drilling.
Morgan
Main scooter: T5 Vespa Mk1
a good idea.......simple, cheap and effective.
Knowledge
Good idea.
I have often seen people struggling to remove the bridge piece secured in the traditional way. It is so much easier if you drop the back shock off first.
I think I might have a go at doing it your way though 10" Terror
Martin
gaz_powell
Nice one I like that!
I like that, I have one of the kits you mentioned but if you don't get the rivets drilled right there is not adjustment.
paul d
Main scooter: T5 172 Tv 240
Great idea!
10 inch Terror
Knowledge wrote:Good idea.
PM me your address and I'll post you a couple of the cage nuts. I have 8 going spare.
Chris in Margate
Simply ridiculously brilliant.
Just ordered from e bay. £1.44
    Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
