Cost of sending an engine?
Timbo
Complete apart from top end. How much for UK and who to use. What's the weight?
YAMLAM
also check the cover value if it got lost or damaged, a lot of courier companies have a £100 limit, unless you take added insurance.
win or lose have a booze
Be careful with the likes of Hermes their T&C exclude engines or parts.
DigDug
rosscla wrote:Be careful with the likes of Hermes their T&C exclude engines or parts.
Don't use My Hermes unless you're not bothered about seeing your engine again.
Did you have to do that?
purple_pill67
Main scooter: Jet200
Drain the oil and pack it well
warts
Main scooter: honda
I sent a very heavy valve amplifier, more weight and cost than a lambretta engine.
I found a www which gave you a list of carriers which you could suss out the t&t's, costs, weights and volumes. The weight turned out to be irrelevant, volume was the thing, with a max dimention limit.
All signed for, tracked and treated well. I did take some care with packaging though - made a wooden crate and put in lots of padding.
Came back in same crate.
I'll have a look see if I can find the invoice.
As mentioned clean and drain first.
If you are sending it to a company, have a word with them see if they have any recommendations.
kennystag
Main scooter: lambretts gp
Hi warts,
What company did you use. Do you have the www one you where talking about for a list of couriers.
Stag
warts
Main scooter: honda
I found them through interparcel. I'm away, so the invoice - if I still have - it is not available ATM.
    Users browsing this forum: No registered users and 37 guests
