Stampede wrote:Which temperature of the cooling liquid can you achieve with the fan and the rad underneath the floorboards?
I´ve mounted my rad behind the front mudguard, unfortunately it´s currently running at about 75°c, which is at least 10° too hot. Thinking of putting a small, second radiator under the floorboards.
hi stampede, sorry i didnt reply sooner, ive been on holiday and didnt notice your post, my temp gauge isnt in degrees, its just red at the top, generaly it stays halfway, especialy when riding,even giving it big licks it stays cool, mines a 4l0 engine and they dont have a thermostat.if i am around town stopping at traffic lights and stop starting the temp can rise up a little higher although my fan does keep it from getting too hot. ive fitted an adjustable fan switch which helps, i think a manual overide fan switch might also be worth having for when im in trafic, the ambient temp also affects the fan switch. a second rad will help you to keep you motor cooler, have you got a thermostat in yours its ypvs isnt it, im sure you can buy a 50 degree thermostat ,also do you have a bypass connected, if not i belive you will need a hole in the thermostat, im also using a chariot high capacity water pump, have you got a fan behind your radiator, that may help,
best regards,
steve
