and a float needle valve
https://www.wasp-performance.co.uk/onli ... e-300.html
questions
1. Can you tell me what the various bits in the picture are for. The ones I think I know are:
a. Top left big circle is for around the float chamber
b. Rubber boot for choke mechanism
c. Largest, right most fibre washer for fuel bango
d. Second most small o ring is for one of the jets (starter I think) - no idea why it needs one but there was one fitted so I replaced it. You can see it in the picture.
e. Second largest fibre washer is for the float chamber bolt
2. The float needle valve did not come with a fibre washer as pictured in the link, and neither was there one already fitted to carb, also I cant see where it would go as if one was fitted it would seem to block the hole in the side of the float. Is this really fitted?
What are the two screw things in the side of carb? I think the right most is obvs the air mixture screw, how many turns should it be turned? Whats the smaller needle one for?
