Gearbox 'tapping sound' in neutral
Fruitjuice
SIL 200 engine, when pushing the scooter along while in neutral there'sa 'tapping' sound like the gear selector is touching the side of a gear.
When running he sound isn't there and will run in neutral on the stand or idling at the lights with no issues what so ever.
I've noticed this noise on several different SIL engines but never on my Serveta or Innocenti engines.
Is this merely a gearbox shimming issue? and would this account for the scooter jumping out of 4th gear under load?
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
holty
Main scooter: lambretta gp
could the sound be the balls in the rear hub bearing all dropping down to the bottom as your pushing it along ?
a.lo.v2
Main scooter: sx 200
Fruitjuice wrote:SIL 200 engine, when pushing the scooter along while in neutral there'sa 'tapping' sound like the gear selector is touching the side of a gear.
i think you could be right about the selector catching the gears. Rimini have brought out a new layshaft that is supposed to cure this problem. something to do with the spring/ ball drilling i think.
Morgan
Main scooter: T5 Vespa Mk1
Kick start plunger/teeth catching ?
HxPaul
Morgan wrote:Kick start plunger/teeth catching ?
The gears dont move when its in neutral.
DigDug
Cable end catching on the wheel/hub or loose wheel nuts.... :?:
Did you have to do that?
EddieStone
I had a similar noise from mine and turned out the rim was cracked. Only found it 'cos I had a flat.
    Users browsing this forum: Semrush [Bot] and 9 guests
