Is this TS1 barrel still useable?
KCB
Hello,
Piston circlip broke and went up the side of the piston :x
Can this barrel still be salvaged and used and if so what is the best way to do it?
As you can see the only real damage is to the boost port edges, can I just smooth these with a dremmel?
Grumpy225
The seize marks all around the boost ports need to be looked in to.
As far as the physical damage to the ports you should be able to smooth them out without too much issue.
KCB
They aren't actually seize marks Grumpy, they are where the circlip tang was dragged up and down the barrel.
I was going to try and carefully polish them out
Grumpy225
They might come out with a hone. Have to find the right shop that can work plated cylinders of course.
Muppet
Grumpy225 wrote:They might come out with a hone. Have to find the right shop that can work plated cylinders of course.
diamond hone for nikasil; id loose the rough edges and run it
C’est la vie
    Users browsing this forum: No registered users and 65 guests
