Gearing issue
Scooterdude
Sorry for the confusion guys, no it does pull like the space shuttle in top (not quite the full 37 million horsepower but near enough) as i say i fitted a 16 tooth front sprocket to replace the original 15, just blasts through the gears and sits there at 55-60 which makes me think just going up 1 tooth may not do a lot, but obviously you guys know more about it than me. will be fitting a JL3 (when it eventually comes).
The barrel is a ported stage 4 i got from Harry Barlow, seems pretty good to be honest.
I looked for the gearing calculator on here but couldent find it do you have a link?
cheers.
HxPaul
Easiest is try a larger rear tyre first.
Boo
Hi scooter dude,
what carb are you using with this set up and what jetting.
just curious.
cheers.
boo
Lambrettas are for life!
Scooterdude
Boo wrote:Hi scooter dude,
just curious.
cheers.
boo
Hi it's a Scootopia sh2/22. 200 slide. 45 pilot, 50 choke, 5899-2 atomiser and 120 main.
Chris in Margate
I definitely wouldn't fit an 18 tooth front sprocket . Unless you have the power you will find it unpleasant to ride.
You will need a longer chain for a 17 tooth front sprocket.
Scooterdude
So will I notice much difference with a 17 tooth over the 16 ??
Chris in Margate
On flat level windless road and on any decline, yes.
Any shortage of power will show itself against the wind or up an incline when in 4th.
2 years ago I overgeared going to France. I had fantastic top speed but on the motorway between Calais and Bolougne I was embarrassing and forever changing down.
olliewtf
Main scooter: Lambretta Li S3
If you've got a jl3 on the way I'd hold off for now; you may find the torque drops off slightly in favour of more revs. Therefore your gearing may be spot on.
Also consider the cost of sprocket, new chain, potentially different chain tensioner etc.
