Transmission oil for Vespa P200e
railfancwb
Looking for information concerning appropriate transmission oil for my Vespa P200e, I found this:
http://www.vespalabs.org/wiki/vespa-101 ... earbox-oil
After reading it a couple times and checking with a local auto parts store for the Castrol mentioned in the article, I have concluded that using some of the 30 weight for 2 cycle engines which I already have would do just fine for the transmission.
Have I overlooked anything? Thanks. Charles
SAE30 is fine as long as it's not an EP oil - it's bad for the phosphor bronze bush in the clutch
railfancwb
Thanks!
Train Driver
I was using Red Line 80W Motorcycle Gear Oil with Shockproof from opie oils but I'm now using
Motul Transoil Expert 10W-40
gaz_powell
Why over complicate - straight SAE 30 lawnmower oil has worked since year dot
