MB Taffspeed Inboard Disc Conversion Slave
Innocenti225
- Main scooter: GP200
Hi anyone out there with any info on the threaded Slave Cylinder used in these conversions? I have had to cut the original one out as it was seized in after sitting Idle for 20 plus years. The one I cut out have both the in valve and bleed valve on the face, but any clues at all to a replacement would be much appreciated...
psychedelicropcircle
- Main scooter: Series 1 li150 1958
Mb would do you another if you sent your back plate.
Innocenti225
Thanks..... the Back Plate is Fine I just need the info for the slave
- Main scooter: Lambretta
The slaves would be custom made - it's not an off the shelf item - the pistons are from a mini or metro four pot caliper and are readily available as are the seal kits.
Innocenti225
Cheers spoke to Taffy at Lyden Hill yesterday and he brought me up to date...Cheersrosscla wrote:The slaves would be custom made - it's not an off the shelf item - the pistons are from a mini or metro four pot caliper and are readily available as are the seal kits.
